This is part two of our two-part series on remediation and the use of artificial intelligence (AI). In part one we introduce the other primary approach to assisting developers with fixing vulnerabilities; traditional remediation and education.
Curated Automatic Fixes
Curated automatic fixes are created by human security experts to address known vulnerabilities found in source code. For simple issues, these fixes can be applied almost instantaneously, even at the level of IDE autocompletion. This approach has been a “tried and true'” method, utilized for years to address various security and non-security issues.
The advantage of these fixes is that they are tested and verified, providing a reliable way to remediate issues without introducing new problems. The consistency of these fixes ensures that the same issue is always resolved in the same manner, enhancing code quality and maintainability.
Such tools provide not only immediate solutions but also educational value, as they are often accompanied by explanations that describe how the fixes resolve the issues. This dual benefit of remediation and learning helps developers understand and prevent similar issues in the future.
If curated automatic fixes have a downside, it is the challenge of their scalability. Since these fixes are hand-crafted, they require significant effort to implement and test for each language across multiple examples and use cases. This labor-intensive process limits the ability to scale the approach to a broader range of issues and languages. Despite this challenge, the effectiveness and reliability of curated automatic fixes make them a valuable tool in a developer's arsenal, particularly for well-known and recurring issues.
GenAI-Driven Automatic Fixes
The third approach to remediation, and one of the most promising, leverages Generative AI (GenAI) to create on-demand automatic fixes. This technology has the potential to offer exceptional coverage and versatility, providing fixes for issues in virtually any programming language.
With GenAI, developers can access automated, on-the-fly solutions that can adapt to various coding environments and requirements, significantly enhancing the efficiency and effectiveness of the remediation process. One of the goals of this method is that with clever prompt-engineering, these AI-driven solutions should be able to generate context-aware responses that address specific problems effectively. This approach promises relatively quick implementation and scaling, making it feasible to handle a wide array of coding issues.
Security Challenges Resulting from GenAI
GenAI makes use of an underlying AI model such as a large language model (LLM) to generate an answer even when it doesn't have sufficient information, which can sometimes result in "hallucinations"—responses that are inaccurate or nonsensical. Because of this there is no guarantee on the quality of the fix without oversight:
  • No guarantee that the solution actually fixes the issue
  • No guarantee that the ‘fixed’ code still functions as intended
  • No guarantee that the solution doesn’t introduce new vulnerabilities
  • No guarantee that the fix will be consistently the same every time, even for the exact same issue and even the same code
GenAI results are dependent on the prompts used, as well as on the quality of the data that the Gen AI model was trained on. While pre-trained models like ChatGPT or Claude are easy to use, these models aren’t always trained exclusively on code, let alone on verifiably secure code.
Fine tuning an existing model is difficult and still doesn’t ensure the model ‘understands’ the vulnerability it’s trying to fix. Training a model from scratch is even more difficult, can be extremely costly, and requires enormous amounts of data. Additionally, any trained model would need to be retrained for every newly discovered vulnerability making scalability nearly impossible.
Choosing the Right Approach to Auto-Remediation
When reviewing the three approaches to remediation and the use of AI, it is clear that while GenAI autofix is a promising direction, there are pitfalls. Organizations still need to maintain manual oversight as a method of checks and balances to ensure they are releasing secure code.
Education, as discussed in part one of this series, is always the best approach to closing the skills gap and making sure that developers are trained to write secure code from the start. And AI has a role to play here as well. HCL AppScan has been exploring the use of GenAI and  LLMs to make the education more actionable by providing users with easy-to-understand summaries of more complex remediation advisories.
Despite the time and resources required, compiling a set of curated autofixes is often worth the effort since the resulting fixes can be trusted to address the vulnerabilities without creating additional issues. It is also worth noting that there is a strong use case for GenAI to reduce the workload of generating and testing curated autofixes.
AI, whether embedded in security testing software, or as part of developers’ user experience, is here to stay. The potential time and resource savings are enormous. Decision-makers today need to consider the potential risks inherent in some of the newer, cost-saving technologies, and balance those against the adoption of curated tools and approaches that they can trust.
Visit HCL AppScan to learn more about the AI and Machine Learning capabilities available today in our application security testing solutions.
HCL AppScan trade show booth with staff, promotional signage showing DAST, IAST, SCA, SAST capabilities and digital metrics display
  |  July 5, 2023
HCL AppScan's Dynamic Start to 2023: A First Quarter Event Recap
Get the scoop on HCL AppScan’s first quarter of 2023 as we recap our active engagement in industry-leading events around the world.
Two developers reviewing code on monitor displaying security scanning visualization and metrics
  |  September 11, 2023
HCL AppScan Integration with ServiceNow Vulnerability Response is now available from the ServiceNow Store
Identify, prioritize, and remediate vulnerabilities faster with the HCL AppScan and ServiceNow Vulnerability Response integration.
Losing Control of Your IoT - A Cautionary Tale
  |  September 13, 2023
Losing Control of Your IoT — A Cautionary Tale
As the IoT landscape continues to expand, security concerns are a key consideration—and collaborative efforts between manufacturers, regulators, and cybersecurity. Learn how HCLSoftware, a provider of industry-leading enterprise security software supports Aleph Research team to mitigate the risks associated with IoT vulnerabilities.
